Cholotl Soul Core Tips: U4GM PoE 2 Bow Build
Все вопросы связанные с сайтом, предложения по улучшению сайта, добавлению/удалению/объединению разделов, то , что вы ходите видеть на страницах нашего автоклуба
glico
Сообщение glico »
The easiest way to waste Path of Exile 2 Currency during a Bow transition is to upgrade raw damage before checking how the build actually clears its maps. In patch 0.5.5, Cholotl's Soul Core of War changes that calculation by giving a socketed Bow a 20% chance to Chain one additional time from terrain. The result is not a simple damage increase. It changes which layouts, pack sizes, and projectile angles produce the best return.
Why Terrain Now Matters
The new Soul Core is strongest when projectiles regularly encounter walls, corners, or narrow passageways. A corridor can turn one fired arrow into several contact opportunities, while an open arena may provide almost no value beyond the weapon's normal projectile behavior.
That creates a clear farming difference between map layouts. During dense clear sessions, enclosed rooms and branching hallways can produce better pack coverage than wide outdoor zones, especially when monsters survive the first hit with roughly 20% to 40% of their life remaining. Players should test the effect against real packs instead of judging it from a target dummy.
Projectile angle also matters. Firing along a wall or toward a corner gives the Chain effect a more reliable surface than shooting directly into open ground. This is most noticeable with skills that already fire several projectiles, because each arrow creates another chance to use the terrain interaction.
Build Around the Actual Damage Profile
Cholotl's Soul Core should support a Bow that already meets its basic damage requirements. If normal monsters require multiple attacks to die, adding terrain utility will not repair a weak weapon. Before changing the socket, establish enough physical, elemental, or critical scaling to clear standard packs in one or two attack cycles.
The Quiver should then solve the build's largest remaining problem. Attack speed improves repeated firing, critical modifiers raise burst potential, and projectile bonuses increase coverage when the skill has several arrows. Defensive affixes remain important because stopping to reposition near walls is dangerous when elite modifiers increase movement speed or incoming damage.
Use the Soul Core for projectile interaction after baseline clear damage is established.
Keep attack speed high enough to maintain pressure during cramped encounters.
Reserve premium crafting materials for gear that improves both clear and survival.
Mapping Value Versus Boss Value
The 20% terrain-based Chain chance is primarily a mapping tool. Isolated bosses, large arenas, and phase transitions with limited nearby surfaces reduce the effect's practical value. A Bow setup that feels exceptional in a corridor can lose much of its advantage when a boss moves to the center of an open room.
For single-target encounters, direct damage and uptime must carry the build. Maintain enough attack speed to keep firing while avoiding ground effects, and avoid sacrificing resistance or life thresholds simply to force more projectile scaling. A six-second damage window is more valuable than a theoretical increase that requires standing still through a dangerous phase.
Players farming endgame maps should consider carrying a second Bow or a different socket arrangement when boss completion is the main goal. The swap costs time, but it prevents a clear-focused setup from becoming a liability at the final encounter.
Common Upgrade Mistakes
The most expensive error is investing heavily in the Soul Core before confirming that the chosen maps offer enough terrain interactions. Run several comparable layouts first, record pack clear time, and compare the result against an ordinary damage-focused setup. A small test sample is better than trusting a tooltip that cannot represent map geometry.
Do not spend high-value currency rerolling every supporting item at once. Upgrade the weapon damage, attack speed, and core defenses in stages, then revisit the Soul Core after the build reaches its intended farming tier. This keeps the resource cost controlled during the transition from early maps to tougher endgame content.
1) Test terrain interactions before committing expensive crafting materials.
2) Farm enclosed layouts when projectile Chain produces measurable clear gains.
3) Keep a boss-focused option ready for open arenas and long phases.
4) Compare completion time, deaths, and resource cost instead of damage alone.
Cholotl's revised effect rewards players who treat map geometry as part of their build rather than background scenery. It is a strong choice for Bow characters that already clear reliably and want more efficient pack coverage in cramped layouts, but it is not a substitute for weapon damage, defenses, or boss planning. Use combat results to guide each upgrade, and compare prices through a reliable poe2 trade site.
