Murmuring Obols are much more useful in Diablo 4 Season 14: Season of Death Awakening than they were in previous seasons. The currency cap has jumped from 2,500 to 25,000, so players no longer have to stop every few activities just to spend their Obols. That extra storage is especially helpful when preparing a new build, alongside other progression costs such as Diablo 4 Gold.
What Are Murmuring Obols Used For?
Murmuring Obols are spent at the Purveyor of Curiosities, which can be found in major towns. Rather than choosing a specific item, you select an equipment slot and receive a random piece of gear from that category.
Common choices include:
• Gloves
• Boots
• Rings
• Weapons
• Off-hands
• Other class-specific equipment
This makes Obols particularly useful when one gear slot is holding your build back. A Sorcerer searching for a better Focus, for example, can target that slot instead of relying entirely on dungeon drops. It is still gambling, but at least you control where the gamble happens.
How to Spend Obols Efficiently
Do not spend Obols randomly just because your currency bar is getting full. Think about your current build first.
Early Season 14: Use Obols to replace weak leveling gear and look for useful Legendary Aspects.
Mid-game: Target equipment slots where your character is noticeably behind.
Endgame: Spend on slots that can produce a meaningful upgrade, especially when chasing better affixes, Greater Affixes, or useful Legendary powers.
Players who regularly buy Diablo 4 Gold should still remember that Obols and gold serve different purposes. Gold covers many general expenses, while Obols give you another way to chase specific equipment slots.
Best Ways to Farm Murmuring Obols
Obols are earned through various activities, particularly events and content involving frequent enemy encounters. Season 14 gives players several activities worth combining rather than forcing them into one farming route.
Good activities to prioritize:
1. Pandemonium Ruptures – These provide dense combat and seasonal rewards while keeping you active in Helltide areas.
2. Helltide events – Local events and monster-heavy zones offer steady opportunities to build your currency supply.
3. Nightmare Dungeons – A good choice when you want Obols while progressing glyphs and collecting endgame gear.
4. Seasonal activities – Events connected to Realmwalkers and Ruptures can add more rewards to the same farming session.
If you are specifically farming Obols, prioritize activities with high enemy density and frequent event rewards rather than spending too much time traveling between objectives.
Don't Waste Your Obol Capacity
The biggest change in Season 14 is the 25,000 Obol cap. You can now save a substantial amount before visiting the Purveyor, which is convenient when you are preparing for a large gambling session.
However, the larger cap does not mean you should ignore it completely. Once your Obols are near maximum, further rewards can effectively go to waste.
A simple routine works well:
• Farm until you approach the cap.
• Visit the Purveyor.
• Spend Obols on your weakest or most valuable gear slot.
• Return to your preferred farming activity.
• Repeat when the currency starts filling up again.
Obols and Season 14 Build Experimentation
Season 14 encourages players to experiment with different builds and chase stronger versions of their existing setups. Mythic Unique changes, crafting options, Enchanting, and other endgame systems give players more reasons to keep testing new equipment.
That makes Obols useful even after your character reaches high Torment difficulties. A gamble that produces the right base item, Aspect, or affix combination can sometimes save a lot of time when rebuilding a character. If you also keep enough cheap Diablo 4 Items available for crafting and upgrading, your overall progression becomes easier to manage.
Final Tips for Murmuring Obols
Murmuring Obols are best treated as a targeted loot tool rather than ordinary spending currency. Keep farming them through events, Ruptures, Nightmare Dungeons, and other activities, then use the Purveyor when you have a clear equipment goal.
Most importantly, do not let the enlarged cap encourage unnecessary hoarding. Once you have enough Obols, turn them into gear attempts and keep the useful results. Combined with Diablo 4 Gold for sale and your regular crafting materials, a well-managed Obol supply can make gearing a new Season 14 build considerably less frustrating.
Farm Murmuring Obols Fast in Diablo 4 Season 14 With U4GM
1fuhd
