U4GM What Winning Online Pitching Tips for MLB The Show 26
Hartmann846
Сообщение Hartmann846 »
Most ranked games in MLB The Show 26 come down to one thing: can you put the ball where you meant to. If you're still trying to win by just ripping 102 up and in all night, you'll get punished. Real people aren't the CPU. They pick up patterns fast, then they sit on them. Pinpoint pitching is the fix, even if it feels rough at first. Slow the input down, hit the shapes clean, and don't panic when you miss early. Once your timing starts to lock in, you'll steal strikes on the black and you'll feel in control, the same way you do when you've got your roster set and you're not stressing about MLB The Show 26 stubs before jumping into a session.
Pinpoint rhythm and living on the edges
People mess this up by rushing. You don't need speed, you need repeatable motion. Think "same tempo" more than "perfect." If you yank the stick like you're mad at it, your release gets sloppy and the pitch leaks back over the plate. When you're trying to dot a cutter just off the outside corner, that little leak turns into a double. Use the aiming feedback, but don't stare at it so hard you forget the hitter. If they're early, you can stay firm up in the zone. If they're late, don't gift them a middle-middle heater that lets them catch up for free.
Tunneling beats velocity spam
Location matters, but pairing locations matters more. A four-seamer up looks great until you show it five times in the same lane. Good players will start cheating, and you'll hear that awful crack. The better play is to make two pitches leave the hand looking identical. Try a high fastball, then a changeup that starts in that same window and fades under the barrel. Or run a slider off a front-door strike look so it ends up on the edge instead. You're not just throwing pitches; you're building a picture, then erasing it.
Counts, habits, and when to bail out
A lot of players go brain-off on 0-2. They'll throw "high cheese" because it feels safe. That's exactly why it gets smoked. Mix in something that tempts them: a breaking ball that begins in the zone and drops out, or a change that looks fat for a split second. Also, watch their swings like it's scouting. If they can't stop chasing low-and-away, keep going there until they prove you wrong. And don't get stubborn with a tired starter. When stamina dips, confidence wobbles, and suddenly your curve hangs. Go to the pen early, keep your tempo unpredictable, and play like every run matters—because it usually does in games where MLB The Show 26 marketplace can mash if you give them one mistake.
