U4GM How to Unlock Into The Void Camo in BO7 Zombies
Hartmann846
Сообщение Hartmann846 »
Season 2 Reloaded doesn't let you "grind" Into The Void so much as it dares you to earn it. If you've been living in pubs and suddenly got the urge to flex an animated camo, you'll find yourself dragged into the limited-time Cursed variants, where every mistake costs time and pride. Plenty of players who usually just farm challenges end up looking at CoD BO7 Boosting for help on the wider progression side, because this one isn't about padding stats—it's about surviving a nasty little secret the mode is hiding.
Where the run actually starts
You queue into Cursed thinking it's just a twist on the usual loop, then you realise the whole thing revolves around relics. You're not simply "finding collectibles". You're turning on modifiers that change how the match feels. Enemies hit harder, timings get weird, and spawns stop behaving the way your muscle memory expects. The first time you activate a relic or two, it's manageable. You'll probably even tell yourself, "Yeah, we've got this." Then your team stacks more and the match turns into a different game, with tighter rotations and way less room to reset when things go sideways.
Relics, thresholds, and the camo tier trap
Here's the bit that catches people out: the camo reward isn't one flat unlock. Running a lighter set of relics can net you a more basic look, but the fully animated Into The Void effect is tied to going all-in. Community testing keeps pointing to the same reality—if you want the top version, you're usually aiming for nine active relics and still finishing the whole sequence. That's why squads argue about risk. One player wants "safe" relics, another wants max rewards, and suddenly you're negotiating your own difficulty curve while the mode is already trying to kill you.
No checkpoints means no mercy
The brutal part isn't even the relics. It's the fact there's no safety net. If your squad wipes during the boss encounter, or someone misses a key interaction, you're back to lobby. No partial credit, no "close enough," no checkpoint to learn the last phase properly. That pressure changes how you build: you'll prioritise dependable damage, emergency armour options, and tools that keep the team moving together. Callouts matter. So does ego control. One greedy revive or one person wandering off for loot can ruin a clean run in seconds.
Why it's still worth the pain
When you finally clear it, the camo feels earned in a way menu challenges never will. The void-like animation reacts as you shoot and rack up kills, and people notice it instantly in multiplayer because it's not common. It's a quiet signal that you didn't just queue Nuketown for two days straight—you handled a high-stakes Easter egg and didn't fold at the end. And if you're also trying to keep the rest of your loadouts competitive while you chase cosmetics, plenty of players use U4gm to pick up game items and services that smooth out the wider grind without pretending this particular camo is anything but a hard fight.
